What causes a row in a table to not be able to 'get smaller'? I am trying to reduce the height of just 1 data row, and for some reason it wont go any smaller than all the other rows. Suggestions?
Solved by dtiemeyer. Go to Solution.
It probably has to do with the text height. AutoCAD places a border around the text that limits the size of the cell. See if you can change the text height of each cell in the row and then reduce the size of the cell.
I've already tried that. Creating a text style with tiny text and linking it to that cell type in the Table Style does not fix the problem. Neither does doing text overrides in the table cells. Good thought though.
Anybody else?
8jwhite, you were partially right. Cheers!
Its a combination of the Text Height & Vertical Cell Margin.
What was causing me problems was merged cells. Once I deleted some merged cells that were spanning the row I was trying to edit, I was able to edit that row with the 2 settings mentioned earlier.
