minimum allowed text height in lisp
Hello.
In one of my lisps, previous programmers had set the text height to 0.006. As a result, because of the type of work we're doing, we need to scale it down after we're finished using the lisp.
Is there a minimum height allowed in AutoCAD for using lisps?
I.e., can I reduce the height to 0.002, 0.003, or something smaller than 0.006?
Thank you.
leothebuilder
Change the lisp file in a text editor........e.g. reduce the text height to what you need
Hi LeoTB.
I have.
I've changed it to 0.002, but what that's doing it adding the input value to the 0.006, making it the input value plus the 0.006.
So, even if I input 0.003, my final height is 0.009, not 0.003.
(if h
    (progn
       (while (< h 0.002)
          (alert msg5)
          (initget (+ 2 4))
          (setq h (getreal msg4))
          (if (null h)
             (setq h 0.002)
       (setq scf (/ h 0.002))
    (setq scf 1)
and yes, I've reloaded the lisp each time I make a new change.
TYIA.
