loading, and accessing lisp routines
Hi.
I'm using 2016, and have several lisp routines.
I've found how I'm supposed to load them, open a directory for recognition, but when I type in the name of the lisp, it's not showing up in the menu which appears during typing of a command.
I've gone back through numerous times (load of lisp is confirmed, opening/inclusion of directory shows), and am not able to identify anything that'd make it clear what I'm missing.
What am I doing wrong?
Your helps would be appreciated.
TYIA.
Never mind. I figured it out. I apparently forgot to edit the name within the Lisp, where
(defun C:PLTST(/ txt h scf n a xincr lay px pzy pins char
asciicod blockname ss nrelem poz b
is initially defined. This post is now answered.
leothebuilder
Did you load these lisps via the APPLOAD command?
Did you add these to the Contents for Start Up?
Including a folder with lisp routines in the Autocad search path will not load these lisp routines.
