Minimize Button Missing and Bottom of drawings are cut off
Hey all,
I'm having a couple issues with AutoCAD 2017.
I was having an issue with the scaling of text, icons and buttons in the user interface (being either way too big or way too small) but found out that it could be fixed by downloading the 2017.1.2 update, which worked, or so I thought...
I then noticed that the bottom quarter of my drawing is not displaying properly (in both model and paper space). Some text and objects appear, but all lines disappear in the bottom portion of the screen. Scaling down the screen resolution fixes the problem but makes everything else look kinda fuzzy. The drawing being cut off was not an issue before the update so I am not sure what is going on. Is there anything that can be done? Or am I stuck keeping my monitor at a lower resolution?
As far as I can tell, my computer is completely up to date (all drivers etc.) I have 2 external monitors and the same problem occurs on either one when the screen is set to full resolution.
Also now the minimize button for the program is missing (or covered by the help button). Right after the update the minimize button was there but then shortly after I noticed it was gone.
I am running AutoCAD 2017 on a Surface Pro 4; i7 processor, 16GB RAM & 256GB HDD w/ a 27" High Def Samsung Monitor and a 24" High Def acer monitor. Running the monitors through the Surface Dock w/ Insignia Mini DisplayPort to HDMI adapters.
swolslegel
I have the same issue and have had this issue for about a month now. I am also on a surface pro.
