Middle button pan in Autocad 2017
RonCollins1955
RonCollins1955
I wanted to get the middle button in AutoCAD 2017 to execute the PAN command.  Hold, move, release.  It defaults to the OSNAPS menu instead.  If I type MB and set it to 1, the middle button works fine.  Once I close and reopen AutoCAD, however, the default is back to OSNAPS.
I then tried to remap button 3 in the CUI to the PAN command.  This works, but I have to manually exit the PAN command to go back to my drawing.  The middle button pan method mentioned above keeps PAN active only as long as I'm pressing the middle button.
How can I customize this permanently so that each reload of Autocad will keep mb 1 as the default rather than mb 0 (osnaps)?
Patchy
One way is to make a ACADDOC.LSP and put this LSP file in your autocad support folder
rkmcswain
It should be noted that MBUTTONPAN is not a drawing stored sysvar and therefore there is no reason it should be changing at startup (from 1 to 0) unless there is some startup code running that is changing it -or- it's never getting stored in the registry at application shutdown.
After you set it to 1, shutdown AutoCAD.
Windows Start>Run REGEDIT
Navigate to HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\Rxx.x\ACAD-xxxx:xxx\Profiles\ProfileName\Editor Configuration
Is there a object there named "MiddleButtonPan"? If so, does the value = 0
TheCADnoob
have you tried saving your workspace after you made the change?
If this option isnt available on the bottom of you screen you can click on the customize button at the bottom right and enable workspace switching
CADnoob
scot-65
Are your scroll bars turned on?
If not mistaken, earlier versions of AutoCAD
required this item to be on in order for
mbuttonpan to work.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
I have the same problem but I don't see any object named "MiddleButtonPan", it goes from "MainDictionary" to "MTextEditor" just as your capture says. What is that mean?
And one more thing, I already checked it up and the value of "MiddleButtonPan" is 1.
Vinayv4v
SYSVDLG and check whether MBUTTONPAN <1> is saved in the registry.
Cheers,
Vinay Vijayakumaran
