Middle button pan in Autocad 2017
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I wanted to get the middle button in AutoCAD 2017 to execute the PAN command. Hold, move, release. It defaults to the OSNAPS menu instead. If I type MB and set it to 1, the middle button works fine. Once I close and reopen AutoCAD, however, the default is back to OSNAPS.
I then tried to remap button 3 in the CUI to the PAN command. This works, but I have to manually exit the PAN command to go back to my drawing. The middle button pan method mentioned above keeps PAN active only as long as I'm pressing the middle button.
How can I customize this permanently so that each reload of Autocad will keep mb 1 as the default rather than mb 0 (osnaps)?
