Where can I find a Text Height Chart in metric:
In Imperial I have all the charts, but in metric cant find any.
1:1
1:5
1:10
1:15
1:20
1:25
1:50
1:75
1:100
1:200
1:300
1:400
1:500
1:1000
What height do you want your text to be?
Remember to scale from Imperial to Metric you *25.4
And from Metric to Imperial you /25.4 or *0.03937007874015748031496062992126
The above are inches/millimetres
Howard Walker
You have to change your drawing units first.
Follow the steps.
Go to ---> Drawing Utilities
Select ---> Units
Change 'Insertin Scale' Units to scale inserted content, into metric.
Now in command: STYLE
Change 'Height'. This will be your default text height.
And then you're all set.
This is based on a commonly used text height in metric for annotation:
1:1 = 3.5mm
1:5 = 17.5mm
1:10 = 35mm
1:15 = (very uncommon scale to use in metric)
1:20 = 70mm
1:25 = (not a common scale to use in metric)
1:50 = 175mm
1:75 = (not a common scale to use in metric)
1:100 = 350mm
1:200 = 700mm
1:300 = (not a common scale to use in metric)
1:400 = (not a common scale to use in metric)
1:500 = 1750mm
1:1000 = 3500mm
