Mesh to solid conversion not working properly in AutoCAD 2019
RemcoK
RemcoK
Hello All,
In AutoCAD 2019 the conversion from mesh to solid doesn't work any more, when I try to convert a mesh (with the "smoothness" set to "None") to a solid the "smoothness" setting is changed automatically to "level 1" during the conversion. This means a mesh box of say 100x50x50 becomes a soap formed solid (and you can't change it).
I use meshes a lot for drawing steel structures because you can stretch an entire frame easily (which you can't with solids). But when I need to convert them to solids I don't want my beams looking like they have been on the bottom of the ocean for a decade (which is what I get now).
This feature has worked brilliantly in previous versions of AutoCAD (2013/2015/2017) with no problems at all.
Alfred.NESWADBA
Works well on my side (using AutoCAD 2019.1.2).
But make sure SMOOTHMESHCONVERT is set to 3 (>>>details<<<)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
RemcoK
Hello Alfred,
Thanks for you're reply, It works fine now, thanks!
pendean
Community Legend
Community Legend
Can you share the CAD file here or others to try?
