Measure angle not showing arc
Message 1 of 8
I seem to have lost the arc that displays when measuring angles and can't seem to find the setting to turn it back on. arc of measured angle shownarc of measured angle shownarc of measured angle missingarc of measured angle missing
Replies (7)
Message 2 of 8
BeKirra
Try this command REGENALL.
Or try this command GRAPHICSCONFIG. Turn off the hardware acceleration.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 3 of 8
HTH
Thanks but tried both and didn't work. Just an FYI both of those screenshots are open on separate files. I'm not sure why it's showing on one and not on the other.
Message 4 of 8
BeKirra
I thought they are on the same file.
Check the dimstyle on both drawings. They might be different dimstyles.
Changing the dimstyle would solve the issue.
HTH
X² + Y² = C²
Message 5 of 8
HTH
Still no go. Just to be clear it's the Measure tool that's doing that, not a dimension.
Message 6 of 8
BeKirra
Sorry, my mistake.
Turn on system variable DYNMODE (= 2) would solve it.
HTH
X² + Y² = C²
Message 7 of 8
Super awesome, thanks!
Message 8 of 8
I was struggling, perfectly worked for me. Appreciated.
