MAXIMIZING inner window within Autocad 2016 creates strange vertical strip/line?
ynemchev
Message 1 of 22
ynemchev
Hi to all,
does anyone know why the vertical line shows up on the right side of the inner window (drawing window) in Autocad 2016? Tried everything, looked everywhere but still cant find a solution for it... I would greatly appreciate any help, that just drives me nuts...
Replies (21)
Message 2 of 22
Alfred.NESWADBA
I can't see that border when my AutoCAD 2016 is maximized, not with Windows 7, not with Windows 10.
What are your system specs, what graphic card do you use, what service pack of AutoCAD do you have installed?
- alfred -
PS: >>>crossposting<<< does not help, it's only more work.
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 22
pendean
Community Legend
Community Legend
Not seeing it here in R2016 either: it almost looks like a scroll bar.
Do you have SP1 installed? What is your Windows OS?
Message 4 of 22
nrz13
That's been a bug for years, although I didn't experience it personally until AutoCAD 2015.  I don't have it on my work computer, but do on my single-monitor home computer.  I don't know of any way to fix it and neither does Autodesk, apparently.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 64GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 5 of 22
ynemchev
Hello again,
nrz13, I've been searching for a solution and came across your post about the same problem, with no solution so far:
https://forums.autodesk.com/t5/autocad-2013-2014-2015-2016-2017/autocad-2015-border-glitch/td-p/4902...
Yesterday I installed v. 2015 and v. 2016 on Win7 machine- problem still there. Today I installed another v.2016 on a Dell Workstation with a nVidia m2000m video card- problem still persists... and now I'm about to give up and roll back to v2014... I mean, do I have an option?
Message 6 of 22
yes its been a bug for years as stated !!!!
Sometimes I see it on both sides and bottom.
Usally I can see my desktop image thru them.
Yes the window is maximized !!!
The top section where the menus are is fine..........
Windows 7 Enterprize 16gig RAM FirePro V3900 certified card.
Ron
Note: 2017 seems to be a little better !!! (Maybe because it does not use the same display engine (Whatever it's called) where 2015-2016 had used a different one. This is when I started getting crashes every day with 2015-16 !
Message 7 of 22
nrz13
Like I said, I never found a solution, although others have reported the same problem in 2011, 2012, and 2014, at least, in addition to 2015 and 2016.  I'll have to check tonight if it's still there in AutoCAD 2017.
Message 8 of 22
ynemchev
I'll post later today as well, as I'm about to install v2017. 🙂
Message 9 of 22
ynemchev
Nope, nothing new in v2017... Smiley Very Happy Unbelievable! I guess I'll using v2013...
Message 10 of 22
nrz13
I just wanted to confirm that the problem is still there in AutoCAD 2017 for me as well.
I wouldn't assume 2013 would be any better than 2012 or 2014.
Message 11 of 22
Yeah this bug drives me nuts everytime i look at right it irritates me beyond level of hardcore annoyance i thought that going 2016 and 2017 would fix this but it still persist oh God why??
Message 12 of 22
I have the same problem in Autocad 2018. I encountered the problem only a few days ago. Also have a problem with the grid of the drawing window and layout windows as you can see in the images below. Why Autodesk don't fix this bug?
Message 13 of 22
Alfred.NESWADBA
Can you please start command _GRAPHICSCONFIG and turn off hardware acceleration ... is the display working then well?
- alfred -
Alfred NESWADBA
Message 14 of 22
pendean
Community Legend
Community Legend
I'm not seeing he grid problem in ACA2018 here, is your version fully updated?
Message 15 of 22
- alfred -
Yes, now the display grid is working well. But the strange vertical strip on the right still persist. It's a bug as i read in the forum so there isn't any solution for it at the moment.Thank you for helping 😉
Message 16 of 22
Alfred.NESWADBA
So it's your graphic card driver, not AutoCAD
For me a bug is something that makes it impossible to work or if something does not work as described in the help.
Please let me know where the problem is (if it's not again the graphic card driver) that you have that small vertical line of 2 or 3 pixel. It is not beautiful, but where is the "real" problem?
- alfred -
Alfred NESWADBA
Message 17 of 22
Yes it was my graphic card driver. Autocad is working with the integrated graphics adapter. I want to configure the advanced graphics card. How can i do it?
- alfred -
I agree with you!
Message 18 of 22
Alfred.NESWADBA
And that is?
Which card? which driver?
- alfred -
Alfred NESWADBA
Message 19 of 22
nvidia geforce gtx 960m
Message 20 of 22
Alfred.NESWADBA
which driver?
- alfred -
Alfred NESWADBA
