Max Number of Named Views
jmartt
jmartt
Sort of continuing from my previous post, https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/list-named-views/m-p/7031467#M352491...
I have a drawing with hundreds of named views.
I am finding more-and-more that I'm missing views that I thought I should have. Now, I could have mistakingly not made the views, (these are named views in modelspace, not viewports), which would totally explain why they're not there, but I'm increasingly convinced that they're disappearing. Which leads to my questions:
Is there a limit to how many modelspace named views you can have in CAD?
and/or
Is there any way to list the number of modelspace named views that currently exist?
To list all the saved Views in the current drawing, you can see them in a dialog box user interface by using the VIEW command and then select Model Views or see them listed on the Text screen by using the command line version preceded with a hyphen: -VIEW then enter ? and * to list all views.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
jmartt
Thanks, @Anonymous. But I wanted to know the number of the views. Counting them, by eye, in a list isn't really a viable option.
Try the attached ViewCount.lsp function.
Unzip file and save into a folder that AutoCAD can find.
Then at AutoCAD command prompt type:
(load"ViewCount.lsp")
When loaded successfully, at AutoCAD command prompt enter command to get a count on how many views are saved in both Modelspace & Paperspace:
ViewCount
jmartt
Hey, thanks. That works. I did notice, however, just because I ran that LISP routine right after creating a new view (named "test"), that it returned
Drawing has no saved Paperspace name views.
Drawing has [1] saved Modelspace name views: (test)
But when I saved and reopened and ran the routine again it returned
But that's okay. Really, good enough. For my purposes, just the number is sufficient and I know I don't have any paperspace views. I'm really just trying to test if I'm hitting some maximum number and it's deleting the earlier views to make room for the new ones. I had 1382 views before "test", so I think I have that answered now. I WAS just forgetting to make the views.
I posted in the LISP forum as well and another version (simpler, which does not return the view names), was provided.: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/number-of-named-modelspace-views/td-...
Again, thank you very much!
