Match Text Orientation Within a Block That is not symmetrical
wjbGQR94
wjbGQR94
Hi everyone,
I have been racking my brain for hours for such a simple thing
I have these 2 blocks I use and I want the text (the text only) to orientate to UCS I have tried everything to achieve this and I've found myself running in circles
I have attached the blocks in question, any help would be greatly appreciated!!
ennujozlagam
first of all your viewport is locked > unlock first > go to mspace click inside > double click the block > go text options > change the rotation to 0. thanks
imadHabash
you can match text orientation to layout , i suggest to follow this article that will help . >> Click <<
Imad Habash
wjbGQR94
Hi thankyou for the reply
I have followed that page already but it didn't affect the rotation of the text within the block at all
ennujozlagam
can you more specific of what are you trying to achieve, and post some screenshot and the one i suggest is not correct? thanks
wjbGQR94
Hi mate thanks for the reply, I think I may have worded my post poorly
The viewport throughout many different drawings is at a different rotation
I wanted to be able to paste in these two blocks into model space and have only the text inside Automatically rotate to "Match Orientation" of the Viewport, rather than manually each time.
Thanks!
wjbGQR94
I want the text within these 2 Blocks to Automatically 'Match Orientation' rather than have to do it manually by adjusting the rotation value (like this white text does below).
MODEL SPACE
PAPER SPACE
If the block itself is set to 'Match Orientation' everything rotates including the Leaders coming off the blocks
I have attached this example
Thanks again for ur help
