Message 1 of 8
09:57 AM
Im having trouble using the mass prop command
I created a solid in fusion. Imported into Autocad 2018.
Want to preform a massprop command to verify the center.
Placed the piece on 0,0,0
Enter Massprop on command line.
I select the part. The text claims that one item has been found.
Yet MASSPROP Select object: remains in the command line.
I press enter....or I press space bar and the same answer comes up: No object found.
and no massprop screen appears with all the spec's
What am I doing wrong?
