AutoCAD Forum
Mass Convert DWGs to DXFs
8 REPLIES 8
Message 1 of 9
sbrusco
767 Views, 8 Replies
Hi All,
What is the easiest/fastest way to convert many DWG files to DXF files?
TIA,
Sal
8 REPLIES 8
Message 2 of 9
in reply to: sbrusco
We can use Publish command for coversion from DWGs to DXFs. In Publish window we can select multiple dwgs.
Message 3 of 9
sbrusco
Hi Apurva,
Thanks for your reply. My options in plot/publish are to PDF, DWF, DWFx, MS XPS, JPG, PNG... but no DXF. Am I missing something?
The only way i know of is from the application "A" to select "Save As > Other Formats" and i'm not even sure if this can be scripted.
Sal
Message 4 of 9
jggerth
that should be scriptable, using the command DXFOUT
Message 5 of 9
sbrusco
in reply to: jggerth
Hi JGerth,
Thanks for the suggestion but i couldn't find a command-line version of the DSXOUT command and as such, i don't know how to script that.
I think we're getting closer. Any other suggestions?
Sal
Message 6 of 9
jggerth
DXFOUT, not DSXOUT.
Try using ScriptPro to set upo your script, but the basic format would be
OPEN
drive:\complete\path\to.dwg
DXFOUT
drive:\desired\path\for.dxf
CLOSE
rinse and repeat as many times as you need in your .scr
Message 7 of 9
sbrusco
Yeah, bad typing skills. But even spelling it correctly as you pointed out, there doesn't seem to be a command line version (-DXFOUT) available. I guess i could test it with a dummy script but will the base command (DXFOUT) NOT open a dialog boxin a script?!
Message 8 of 9
jggerth
running DXFOUT in a script should automagically run command-line only and not fire up the dialog.
to play it safe though, you could always start the script with FILEDIA 0
Just remember to reset it when you are done.
I understand about typeing skillz -- same thing haooens hereSmiley Wink
Message 9 of 9
sbrusco
Thanks. I'll give it a go.
AutoCAD Inside the Factory
