MANUAL RESET OF SYSVARMONITOR SETTINGS TO DEFAULT
DanHartel
DanHartel
I'd like to manually reset my sysvarmonitor values to AutCAD 2022 default.  Can someone please post a screenshot for me?
I don't want to use the "Reset Settings to Default" routine found in the program's directory since it will remove the aftermarket software platform that sits "on-top" of AutoCad. Very cumbersome to reinstall.
Attached is a screenshot of my current arrangement which I want to change back to the "Out-of-the-box" default settings
pendean
Community Legend
Community Legend
All the default settings are listed in HELP for each of those variables: start there while you wait.
Patchy
I don't have this option with my old Autocad, but what is this for?
pendean
Community Legend
Community Legend
@Patchy That button just sets these user defined options already in the list, which may not be what the OP wishes
RAFUSE
Don't know why you want to do this.
To reset all mine to "default" would totally mess up my using Autocad!.d
You do know you can save the current settings to a file to use to get you back to where you are when you save the settings?  I have used it several times and always keep a current one in case something screws up.  Came in handy several times over the years.
R
Michiel.Valcke
As requested; this is the out of the box Sysvarmonitor:
These are the default values of your monitored sys vars:
cadffm
@RAFUSE
You missed the topic
@DanHartel
While program is closed, delete the whole registry key of sysvarmon of your profile
(if you need that often, create a button to do that by lisp or .bat/.cmd file)
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\Rxx.x\ACAD-xxxx:xxx\Profiles\<YourCProfileName>\SysvarMonitor
OR, if you don't use the startup suite (appload/startup) , or if it is easy to restore for your:
Start AutoCAD with a new profile (start parameter /p )
and switch to your profile.
Sebastian
