Making Font file and shape files.
Muhammed.OPERA
Advisor Advisor
Message 1 of 15
Muhammed.OPERA
Hi everyone,
1- I'm making a new shx font ( just to help us to write in Arabic ),
Every Arabic letter have many curves, I managed to draw our letters as splines and polylines, but now i'm asking what's the rightest thing to do:
Convert ( Spline ) letters into shapes (SHP), or convert ( polyline ) ones , or explode them then convert ??
2- When i convert any curve into SHP, it askes for resolution and the default is 128. when i keep it 128, the shape was not accurate.
When i use higher resolution, it become to be more accurate but the problem is that in the SHP file it use letter subshape and i don't know how to deal with that in turing the whole letters into SHX font.
How can i make the curve accurate and inside the limit without needing to use any subshape in the SHP file.
Thanks 🙂
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
Replies (14)
Message 2 of 15
J.FOCHT
Here is a nice detailed post about making your own font file. This should help you out some more.
https://forums.autodesk.com/t5/autocad-forum/how-make-shx-font-file/td-p/2025099
Here is a nice website also:
http://docs.autodesk.com/ACD/2011/ENU/filesACG/WSfacf1429558a55de1a7524c1004e616f8b-32e9.htm#WSc30cd...
Hope this helps you out! This is a big process.
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
Message 3 of 15
Muhammed.OPERA
Thanks for your very useful comment @J.FOCHT
Did you work on something like that, i just want to ask for some small details if you can 🙂
Facebook |LinkedIn
Message 4 of 15
J.FOCHT
A coworker was working on it in the past and i assisted him at points along the way. I'd be glad to help in anyway i can, though im no expert on this process by any means.
Thank You!
Jonathan Focht
Message 5 of 15
Muhammed.OPERA
My only proplem now is with curves, Every arabic letter consists of huge number of arcs and splines,
Every time i convert arcs or splines into shape it become crazy Smiley Sad cracked .
Sure it become more fit when i increase the resolution.
is there any tips from you on this problem.
Facebook |LinkedIn
Message 6 of 15
J.FOCHT
Hello @Muhammed.OPERA!
Could you please attach a sample so that i can work with it? Perhaps one with a lot of arcs and splines. I need to brush up on the process a bit.
Thank You!
Thank You!
Jonathan Focht
Message 7 of 15
Muhammed.OPERA
@J.FOCHT thank you
that's a drawing of one sample:
http://www.mediafire.com/file/xcjk55qnlqu1xdx/UCH.dwg
Facebook |LinkedIn
Message 8 of 15
J.FOCHT
Thank you for sending a drawing for me to look at.
One thing that i remember doing is that i would convert the spline to a polyline.
Select the spline, stype SPLINEEDIT, then converttoPolyline option.
See if that makes it easier for you. I will look into working on the drawing you sent.
Thank You!
Jonathan Focht
Message 9 of 15
Muhammed.OPERA
Yup , I used that command before (i said) , I tried to make SHAPE 3 times of ( Spline , Polylines , Lines ) .
The problem is that it's not accurate shape unless i use very high resolution.
Using high resolution No. makes the .SHP file consists of many subshapes , i don't know how to deal with subshapes into the SHX collection.
Facebook |LinkedIn
Message 10 of 15
J.FOCHT
@Muhammed.OPERA,
Many apologies! I am encountering the same issues as you are. I am experimenting with different tweaks to the drawing and shape but they are proving fruitless.
Thank You!
Jonathan Focht
Message 11 of 15
Muhammed.OPERA
Thank you @J.FOCHT for your effort 🙂 and for your time
is there any one can help us with that ?!
Facebook |LinkedIn
Message 12 of 15
J.FOCHT
It has been my pleasure. I can get it to work but i hit the same problem with the shapes as you. Perhaps we can get the developers involved to help. We are almost there!! Ill keep working on it and see if i hit a breakthrough.
Thank You!
Jonathan Focht
Message 13 of 15
Muhammed.OPERA
Ok.
Thank you very much @J.FOCHT 🙂
Facebook |LinkedIn
Message 14 of 15
john.vellek
Hi @Muhammed.OPERA,
I palyed with your file that you shared with me privately. On the lower part of the character I replaced the SPLINEs with simple arcs. I then used a resolution of 350 and it didn't turn out too bad.
Can you try this too? Or, send me your email privately so I can send you my file to look at.
John Vellek
Message 15 of 15
Muhammed.OPERA
Thank you very much for your time 🙂
can you please send me the file in private
Facebook |LinkedIn
