Making Drone frame questions - dimension linear tool, export format STL, extrude 3d, snap weld tools
mmurakami500
mmurakami500
Hi, I am a senior VFX aritst who knows a fundemental for 2D/3D sfotwares, but a beginner for AutoCAD.
Using AutoCAD 2022, my procedure is:
1 Draw 2d drone frames. Parts can be only 2-3kinds, relatively very simple shape.
2 Apply thickness for some parts as carbon frames, and do a simple/quick 3d-models for TPU/plastic objects.
3 Make sure those parts are consistent in 3d space.
4 Export  DWG for carbon frame and STL or STEP files for TPU object.
Then, I have multi questions.
A
When I use a dimention linear tool, sometimes that text parts are gone, although I tried to modify Text height from 0.0001 to 9999.  How can I get back the text??
no dimention textno dimention text
B
Because of a beginner, I sometimes noticed I did double copy and placed twice, and lines/curves are doubled. Do we have a tool which lines are doubled and how to remove those wasting lines?
left is double circles and right is single circleleft is double circles and right is single circle
C
The below drawing is an example from a friend. This drawing is made with 5 lines, and each start/end are just snapped. Is this common way to draw in CAD?  This is because I must connect/weld start-end points in a 3d software like Blender when I am creating a 3d-model.
D
There is a polyline?! object, and I think accidentally converted it. Can I convert back to spline object? PEDIT shows spline command/option but seems to not working. So I guess this covertion is one way...
polyline objectpolyline object
When extrude drawings, simple circle line creates 3d volume objects, but my drawings are not working properly (E1). Next I joined all curves and apply Extrude(E2). Then object is gone!!
What's the requirement to be able to 3d objects?
exrude2.JPGE1
44abe28c-f45e-41c0-a42e-27fabd5d12ca.jpgE2
5d0979a8-8873-4dc0-9e35-c49bb13bfbe7.jpgE3
Eventually should I switch to use Autodesk Inventor?? Or AutoCAD will handle my goal?
Thank yo so much for your assistance!!!!
imadHabash
Hi and Welcome to AutoCAD Forum,
Would you please attache here your CAD dwg to give you a direct answer?
Imad Habash
mmurakami500
To imadHabash
Thanks for your quick reply!! So I solved a couple of problems, but got some new questions too.
I attached a dwg file and new screencapture png showing new summarized questions, totally 6 questions. Hopefully my questions are clear, and you would find answers quickly, thanks!!
