@paullimapa wrote:
That’s strange because I’m not seeing a selection window appear when I run Copy command. All I see are what objects are ignored and that appears as Text on the Command line
Do you not get this? At a select-objects prompt, hover over where there are multiple objects, so you see the little overlapping-squares icon [to the upper right of the empty white square which is my pickbox]:
then pick, and you should get the tell-me-which-one-you-want dialog box-let:
and that includes the yellow Line which is on a locked Layer here. @jatin_sanskrit , is that what you're talking about, but by a Layer you would designate, not necessarily by Locking it? I assume you don't want that to come up at all if all but the thing you want to pick is/are on locked Layers [or your designated un-selectable Layers] -- you don't want to be required to narrow it down when there's only one selection possible in the command you're in. I don't know of a way to limit selection in that way, but there are multiple threads on the same question relative to Locked Layers, that you can Search for. I think the biggest problem may be that there are commands for which being able to select even things on locked Layers needs to be available, particularly as TRIM/EXTEND/HATCH boundaries.
Kent Cooper, AIA
