Hello all!
I am working on some architectural drawings in AutoCAD.
I have my units set to Architectural with precision at 0'0"
When drawing for instance a 2ft line,
I'd like to be able to type 2 and then press enter without pressing the ' key
AutoCAD defaults this to inches
Is there anyway to make feet the base unit?
Solved by natasha.l. Go to Solution.
Hello @Anonymous,
Thanks for posting & being a part of Answer Day.
You can type & use the UNITS command, specify an array of things in this case you would change the "Drawing Units" to feet.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hi Adam,
Thank you for posting in our forum. Do you find Natasha's reply helpful? Feel free to let us know if you have any doubts on the settings.
Best Regards,
Mi Le
What's been suggested is what Civil Engineers do regularly. But do you want to be able to use Architectural type Dimensions, showing feet and inches and fractions, or Engineering type with feet and decimal inches? If that's needed, the drawing unit must be an inch.
