You can try DOBT (DrawOrder By objectType; freeware) or the LAYERORDER command in AutoCAD Architecture. See:
https://www.cadforum.cz/en/qaID.asp?tip=5905
Vladimir Michl, www.arkance-systems.cz - www.cadforum.cz
I have equipment tag block with wipeout that has to be always on top. Any leaders I draw to the equipment from this tag block has to start at the center of the block. I use draworder command to put this block on top of the leader and regenall after. I have to use the same layer for both block and leader means I can't send all objects on this layer under or on top.
I've tried dobt but so far I understand that I have to modify this lisp to fit my need, correct?
You can add a line:
INSERT yourtagblockname
to the definition table below the ^^^^^ line - this will put all your tag blocks always to the top.
I did load dobt
(Command: DOBT, DOBT? commands loaded. (C)2021, www.arkance-systems.cz
_____ CAD, BIM, GIS/FM custom application development ______)
This is what I've got
(Command: DOBT
Dobt.tab NOT FOUND!
0 objects processed)
after I modified
;and now - send these to TOP (rise)
INSERT kclrec4
Command: DOBT
DOBT.TAB LOADED (13 definitions)
0 objects processed
If the LISP doesn't end up working out, you could try putting your tags and each equipment drawing inside a block together. I've found AutoCAD only reliably maintains hatch and block draw order inside blocks.
LAYERORDER - command, TEXTTOFRONT - Command and HATCHTOBACK - commands could be used.
I suspect they are aware of those commands. The issue is a persistent bug in AutoCAD where the set layer order of elements is lost, at least visually if not actually. The only workaround I know of is still to put whatever elements needing to maintain a specific layer order all inside a single block.
