Macro to turn off all layers containing certain words
tony_prall
Observer
tony_prall
Observer
Observer
Hello, new to using macros and stumbling through this, I have a client that i do work for and every file always has certain layers i need to turn off, example i normally do *cat*  in the search to show all the layers with that word in it and select all turn off, then *dim* do the same, so forth and so on, is there a way to make a macro where i hit one button and it goes through all the layers with certain key words and turn them off?
this is the 6 i always have to turn off and freeze.
cadffm
The command is
-LAYER
Type in, press enter and you will see the syntax.
Example:
'-LAYER;freeze;*dim*;;
For example, to
Sebastian
tony_prall
Observer
Observer
so could i just type in
'-LAYER;freeze;off;*dim*;*zon*;*aisle*;*text*;*sect*;*cat*;lab*;;
and that would do them all for me? or does it not work that way?
Kent1Cooper
Freeze and Off are separate options in a Layer command.  No reason to turn them off if they're frozen, really.  Multiple Layer names [including those with wildcards] that you want to apply the same option to need to be comma-delimited:
'-LAYER;freeze;*dim*,*zon*,*aisle*,*text*,*sect*,*cat*,lab*;;
If you do want to also turn them off, you need to invoke the Off option and list them again under that.  But at least you can combine multiple options within one Layer command:
'-LAYER;freeze;*dim*,*zon*,*aisle*,*text*,*sect*,*cat*,lab*;off;*dim*,*zon*,*aisle*,*text*,*sect*,*cat*,lab*;;
Kent Cooper, AIA
tony_prall
Observer
Observer
awesome thanks Kent, that works great!
