Macro scale basepoint
Iam having trouble with my macro for scaling.
i have over 5000 drawings that i need to scale from meters to milimeters.
each drawing has a defined basepoint that is custom to each drawing.
is there a command or something to make it select the original selected basepoint when i am using the scale command?
i dont want to select 5000 basepoints individualy.
ВeekeeCZ
@Anonymous wrote:
... each drawing has a defined basepoint that is custom to each drawing. ...
How? Post a sample drawing with removed sensitive content.
here is an example drawing
ВeekeeCZ
Ok, I see. So your trouble is that you know how to write such macro, just don't know how to retrieve the base.
BTW you're using full acad, not LT?
Im using full autoCAD yes.
Indeed i made the macro with the record button in autocad.
the thing is when i make the command scale and select all is asks to specify the base point when each drawing would have 0,0 is would be easy but each drawing has a specific basepoint and i was wondering if there is a command or something that it would look at the original basepoint.
now i need to check with eacht drawing for its original basepoint and than i need to select that point with scaling.
A few drawings would be no problem but over 5000 is a bit of a pain.
ВeekeeCZ
Ok, then use this expression
(getvar 'insbase)
to get a ref point. You don't need to test whether it's defined or not.
