LTSCALE (Command) vs. Properties Linetype scale
ndawsonmccann
Message 1 of 8
ndawsonmccann
I recently saw someone use the LTSCALE command, which I was somehow unaware existed. I am used to changing the linetype scale under the properties window.
It seems as though both operate separately from one another. I ran a quick test where I drew a line with a DASHED linetype scale of 1.0 then I typed in the LTSCALE command and entered the number 2, which visually changed the linetype scale on my screen and when printed. However, that same line still shows a linetype scale of 1 under properties instead of 2. What am I missing here?
Thanks, Nick
Replies (7)
Message 2 of 8
GrantsPirate
LTSCALE is a global setting for the drawing and generally much preferred over changing the objects linetypescale.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 3 of 8
RobDraw
LTSCALE is drawing properties variable and is applied to all linetypes and affects the entire drawing file. The properties line type scale is entity based and is a multiplier to the LTSCALE value.
Rob
Message 4 of 8
ITandCADguy
There are two other system variables that go along with the global LTSCALE.
MSLTSCALE (1=ON) will match the LTSCALE to the model space annotation scale.  If it is set to 1 and you change annotation scale, the linetype spacing will change to match when you regen.
PSLTSCALE (1=ON) is just like MSLTSCALE except it applies to viewports in paper space.
Message 5 of 8
Hi there:
LTSCALE is also tied to the current "Annotation Scale" in Model Space, so you do not have to keep on adjusting manually at different Scales.
Message 6 of 8
scot-65
If you wish to see another visual example, try this on an unsaved DWG file:
Set DIMLFAC to 0.5 and replicate an existing dimension. It is basically the
same principle.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 7 of 8
ndawsonmccann
Thanks for the help everyone!
Message 8 of 8
BillW435
Thanks you all. Nick wrote: " I am used to changing the linetype scale under the properties window." That's what I have been doing also. Appreciate learning the other methods!
