I am trying to export my design to pdf or jpg to physically print out, but since the design is so small (the smallest features are 25 micron circles), the pdf and jpg conversions do not give me a high-enough quality rendering to use well (e.g. 50 micron gaps are filled in). I tried changing DPI settings to various high numbers (2400, 4800, 9600) under PDF options when I try to export under "DWG to PDF", but it didn't work since the pdf that came out looked the exact same every time.
Solved by woodenlious. Go to Solution.
Solved by Alfred.NESWADBA. Go to Solution.
how about trying plotter AutoCAD PDF ( High Quality Print ) ?
Imad Habash
Hey, assuming you are using _PLOT as you are referring to "PDF options" ... how did you set DPI to 9600 ... that is not available in AutoCAD, the maximum resolution is 4800dpi:
Also please show us a PDF (or better 2 PDF's plotted with different resolutions) and describe what is bad with them.
Simply thinking about 4800dpi it's quite difficult to see that on the screen, even zooming in very close.
Just a few tips when quality in PDF's can look lower than expected:
And just thoughts...maybe I assume something wrong, but lets see:
Are you expecting to get a PDF that is later used to print 1:1?
Just to verify that ... 25micrometer = 0.025mm ... if that is the diameter of a circle and you need to plot that with a lineweight so the circle is not filled you need to have a lineweight <= 0.008mm (0.0003 Inch) (and even that will show the circle just as square with 9x9 pixel).
So I assume that is not printed for looking to that PDF with eyes, instead the PDF might be used for some type of production and now you should take care of: a PDF does not store vectors with double precision, the circles you get in the PDF are not at the exact position you have them in CAD-X/Y (based on double precision coordinates) and also not with the (double precision calculated) radius. The coordinates of X/Y and R inside a PDF are based on raster values(pixel), accuracy of double precision is definitely lost and so the quality of your small circles too.
I strongly recommend to transfer such objects in a real cad format, not with PDF to your production.
- alfred -
Thanks for the replies!
I tried doing the "AutoCAD PDF (High Quality Print)" with 4800 DPI but the quality came out the same as it did for other ones; I'm pretty new to AutoCAD and not exactly fantastic with computers, so I couldn't tell if it was a problem on my PDF end or with the plotting end. I did try the "PublishtoWeb JPG" plotter setting, but the quality was just as bad on a jpg so that made me think it wasn't a pdf problem (although I can't be sure).
I attached the PDFs of when I do the high quality print with 2400 and also 4800 DPI rastor and vector (not sure what those are but I just went for the highest possible), and also a screenshot of what it actually is supposed to look like in AutoCAD. When you zoom in on the PDF, you can't see the channels that are on the close-up screenshot that I took (and yes I am hoping for some kind of 1:1 printable format that I can then send to a printing company like FedEx Printing to print for me).
What do you mean by transferring in a real cad format?
Well, your lineweight you used to plot is much too thick, and using small circles, but thick lineweights, is what you get as result.
Can you tell us a bit more about what you are doing then with the PDF's, whatfor are they needed?
- alfred -
I am a bit unsure on how to change the line weight; I went into the plot style editor and changed some of the lineweights for a few colors including the colors I used in AutoCAD but it didn't seem to have any effect on the plotted model. The PDFs are just intended for me to have a version of the model of those channels that I can send to a printing company (or print myself on a laserjet). I would want to print it out with a 1:1 ratio on transparency sheets so that the areas inside the rectangular features are transparent, and the areas inside the circles and also outside the rectangles are all dark. I would use this transparency to fabricate channels in the lab of the same dimensions as in my model.
Kidding? You know that your laserjet never supports 4800dpi (or do you have a print shop that has really high end devices?)
If you do that just as try and error without knowing what you are doing then this most probably fails (sorry for the words, but gaming with the CTB file/settings is the last I would do just to control lineweights).
Don't use CTB or STB at first, start your layermanager and give all layers the lineweight "0.00" which is then the thinnest lineweight possible, then make sure all your objects in the DWG-file have lineweight assigned to "byLayer" and now you are able to plot.
You might upload the DWG-file and I do that for you, just to make sure you have a one-time correct setup.
But I can't make your laser printer printing with 4800dpi. 😉
- alfred -
ME SAME PROBLEM 1 WEEK CANT FIND SOLUTION IMAGE EXPORT VERY BAD QUALITY AS 600X400 OR 3GP EVEN ITS HD RENDER PHOTO DIFFRENT TOTALY THAN AFTER EXPORT AS PDF FROM AUTOCAD -I TRY ALL PLOT SITTING HIGH QUALITY OR MAX DPI AND ALSO ANOTHER EXTERNAL APPS AS NITRO OR CUTE PDF BUT NOTHING WORKS ALL OPTIONS LOOKS FAKE ,WAITING THE SOLLUTION THANKS
