Lost the on screen right click menu 'select similar' command
kiarianc
Message 1 of 10
kiarianc
I've configured my AutoCAD so that my right mouse button operates as the 'ENTER' button. I type C for example, and right click, a circle command instantly is on screen. This bypasses the normal right click menu screen which usually comes up, and is a much faster way to work in my opinion.
How do I get the default right click menu to appear? At the moment I hold SHIFT and then right click to get the OSNAP setting menu window, but how do I get the standard right click window with this 'selectsimilar' command?! Can't think how to do this. If there is anyway of doing this, and keeping my preferred way to work (using the right mouse button as an ENTER button), then let me know.
Replies (9)
Message 2 of 10
jackshield
in tools/options/user preferences
right click customizations
you have some options, including delay which allows the right click to do both, enter, or menu
if your using it just for enter, after a key stroke, may i suggest the space bar, its right there by your thumb
Message 3 of 10
kiarianc
Thanks. Experiementing now. Now I'm not seeing the 'selectsimilar' command at all in the default right click menu. Strange?!
Message 4 of 10
sthompson1021
Select Similar is not in the OOTB default shortcut menu. It is in the edit shortcut menu so if you click on a object and then right click it should be there. If you want to add it to the default menu, you can do so in the cui.
Message 5 of 10
scot-65
Possibly tinker with SHORTCUTMENUDURATION
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 6 of 10
Satoews
If your looking for a faster way of getting basic commands done id like to sugest a different mouse.
Razer Naga
With 16 buttons you can have a whole group of commands at your fingertips. For instance i have:
Esc
Enter
P
Ctrl enter
Model view
Layout 1
Layout 2
Layer 1
Layer 2
Layer 3
Close
Ortho
Snaps
Line
Circle (with enter at the end of the macro so you don't have to press)
Shawn T
Message 7 of 10
kiarianc
That's the answer. Using the cui I've dragged the command over to the shortcut menu object snap cursor (which is the menu I get when I right click) and also to the default shortcut menu as well (the menu I get with a longer press of the right mouse button).
Should speed things up. Cheers.
Message 8 of 10
kiarianc
I'm using a 3DConnexion Cad Mouse. By far the best mouse I've used for CAD. I'd put money on this mouse, in the Octogon, against your mouse. 😛
Message 9 of 10
johncollins6287
I found that the PICKFIRST variable had set itself to 0, instead of 1. This is why we were missing "Select Similar" even when selecting objects before right-clicking.
Message 10 of 10
posto-1
Community Visitor
Community Visitor
THIS is the real reason that the selectsimilar command was dissappeared. THANKS.
