Losing selected objects when changing views
When I have an object selected in plan view, and switch to perspective, the object gets deselected???
autocad 3D 2013
dannyk
I would recommend to setup your screen to a Vports configuration so you can select in any VPORT and move to the other one
dannyk
imadHabash
Hi and Welcome to AutoDesk Previous,
I suggest to use Previous (P) when you switch to another view and while asking for select objects. select your objects in plan view then make fake(uncompleted) command like move or copy then cancel it switch to another view and active your needed command and when asked for select objects type P
Imad Habash
dannyk
I guess this is not as good as Configuring Your Screen Using VPORTS since
it's not transparent. You Select something, move to a view and use previous
but' to select again, you need to go to the plan View again, a bit tedious,
while moving from one vport to the other, is transparent, you pick a
selection in one viewport, move to the other one, and your selection is
still active!
Danny K.
Danny Korem ,
*"Distilling Exactly the CAD Knowledge You Need"*
sophisticadd.com | +972-54 7786115 |
*Follow Me:*
LinkedIn Profile: https://il.linkedin.com/in/dannykorem
Autodesk Profile: https://knowledge.autodesk.com/profile/LXTIZOKBP41M3
*Subscribe to:*
sophisticadd: http://www.sophisticadd.com/contact/
YouTube Channel: https://www.youtube.com/channel/UCoEp2HW9vYpDhax3uAPmLdQ
dannyk
dannyk
still active!
Danny K.
Danny Korem ,
*Follow Me:*
*Subscribe to:*
dannyk
Since I'm not a big fan of splitting my drawing screen, I usually invoke the PSELECT command, then get my last selection with P (like imadhabash wrote).
Anyway, the dannyk's solution is also nice.
Thanks ...
leaf.png ¬
*Russell Stephanchick*
Exhibit Designer
Eco-Systems Sustainable Exhibits
d: 616-726-6267| e: russell@ecosystemsdisplays.com
w: www.ecosystemsdisplays.com
a: Corporate Office: 401 Hall Street SW - Suite 409 Box 66 - Grand Rapids
MI - 49504
a: Production Office: 5675 SE International - Way Portland OR - 97222
facebook.png ¬ twitter.png ¬
youtube.png ¬
IMPORTANT: The contents of this email and any attachments are confidential.
They are intended for the named recipient(s) only. If you have received
this email by mistake, please notify the sender immediately and do not
disclose the contents to anyone or make copies thereof.
2015 Winner in "Best Design" from Exhibitor Magazine.
pma.jpg ¬
