Lose Image Path After Copy Past
When I copy an image (jpg) from one CAD window to another I lose the path for the image and I can't see the image once I paste it.
Do you know why?
I have been reading about path types.
There seems to be 3 options, full Path, relative path and no path.
I think I want full path but I can't find a setting for it in CAD.
Cadologist
If you open the Reference Manager then select the image listed from the references list, you can select the pathing type.
Chad Franklin
john.vellek
Hi @Anonymous,
I made a quick video of what you are describing. Can you confirm that you are seeing or not seeing the behavior I show?  It sounds like your clipboard is failing. Or are you seeing the image frame but no image?
Please give me a bit more detail so I can give you a bit of help.
John Vellek
I like to drag me images from windows explorer and wanted to avoid changing the path of the images every time I want to copy them over to another drawings.
Is there a setting that will allow me to always attached an image with PATH ABSOLUTE?
There was no volume and it was hard for me to follow what was going on
Cadologist
I don't believe there are any system variables that can be configured to specify a 'default' pathing type. I would assume this is because of the functionality presently in the Reference Manager, which allows for a user to customize any pathing requirement as he/she fits to fulfill any requirement. There could be risk associated with defining 'no path' as an example for references, through the use of a system variable option.
Chad Franklin
