Looking for Texas Outline DWG
I'm new to AutoCad having designed for many years on VectorWorks and SketchUp Pro.
I'm using AutoCad 2017 and am trying to find a DWG file with an outline of the State of Texas.
I am working on plans for a laser CNC metal fabricator who insists they must be drawn in AutoCad using Polylines.
I know I can import an image and trace it but was hoping someone else might have already done this.
Please help.
Thanks!
Joe
Replies (7)
john.vellek
HI @Anonymous,
I grabbed an Adobe Illustrator one off the web and converted it to a DWG. I hope this works for you.
John Vellek
rkmcswain
Here is Texas and 49 other smaller states. (I know what you are thinking, but open the file....)
R.K. McSwain     | CADpanacea | on twitter
chriscowgill7373
C'mon R.K  Alaska is a whole lot bigger than that.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
rkmcswain
Hey, I didn't draw it. This is probably ±20 years old. You can probably find a copy floating around out there somewhere.
5 second google search=
This is probably it:
http://www.cnczone.com/forums/general-metalwork-discussion/284218-usa-map-dxf.html
Cheers
pendean
Community Legend
Community Legend
Ask a Texan! See attached.
Kent1Cooper
A web search for something like "United States .DWG" will reveal a lot of sources, such as this.  You might want to compare several, because they will no doubt have different levels of detail in the more convoluted parts [the coastline, the Rio Grande edge -- quite a difference between the images in Posts 2 & 6 here] -- depending on what you're using it for, a highly-detailed coastline may be much more than you need and therefore consume a lot more memory than necessary.
Kent Cooper, AIA
I apologize for the delayed response.  My cable internet service has been down since yesterday afternoon.  Houston has a long recovery after the damage from Harvey.  (Obviously, the folks in Florida have just as much rebuilding from Irma.)
Thank you to everyone who responded.  I really appreciate it.  @pendean's attachment is exactly what I needed.
I did several Google searches before posting but didn't find what I needed or at least didn't recognize it as such.
With SketchUp Pro, there is a 3D Warehouse which is a repository for this type of drawing created by other users.  Does Autocad have anything like this?
Also, is there a method I can learn to convert items from a PDF or JPG file to AutoCad?
Many thanks!
Joe
