- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone, I’m building a CAD standards package (trying to, but it is very difficult, and a little scary) and I’m trying to finalize the CTB setup before I lock everything in. I'm planning to use monochrome.ctb, but I’m still figuring out the best way to structure the color and lineweight system, so it stays simple and consistent. I posted a question the other day and received great help! And though, as stupid of a question it might be, would this approach even work?
Right now, I’m considering a hybrid approach. The idea is to use colors 1–10 for normal black linework, each tied to a specific lineweight, and then use colors 250–255 for screened grayscale items like existing conditions, backgrounds, and underlays. Layers would still control lineweights, and the CTB would only handle black vs gray output.
For example, in my current layer setup (with just layers and lineweights) I have interior walls on yellow at 0.25 mm, exterior walls on color 20 at 0.35 mm, furniture on color 201 at 0.13 mm, and plumbing fixtures on color 140 at 0.18 mm. If I switch to the 1–10 and 250–255 system, I’d need to remap these layers to the new color scheme while keeping the same lineweight hierarchy. Is that even allowed? I know every person and firm and discipline is different, but my fear is that it is isn't accepted or is far from what most have done themselves.
Has anyone used a setup like this for architectural drawings? Is this a good balance between simplicity and flexibility, or am I making it more complicated than it needs to be? I’m trying to keep things easy while still allowing for screening and a clean architectural look.
So what I have so far is I have some lineweights already, can you tell me what you think? For my custom .ctb, I have color 1 (Red) set at 0.10mm, color 2 (yellow) set at 0.18mm, color 3 (green) set at 0.15mm, color 4 (cyan) set at 0.25mm, color 5 (blue) is set at 0.15mm, color 6 (magenta) is set at 0.35mm, color 7 (white) is set at 0.05mm, color 8 (gray) is set at 0.10mm, color 9 (gray) is set at 0.13mm, and red-ish (color 10) is set at 0.10mm. So magenta is thick line, cyan is medium line, yellow is thin line, red is superfine line, and green is dashed line.
Any feedback or examples would be appreciated.
