looking for a way to calculate external surface area of a complex 3d solid
mvr_asp
Message 1 of 16
mvr_asp
Hi there all
I have a complex machine drawn in 3d solids in AutoCAD.
I need to provide the approximate external surface area to be painted,  this machine looks like a large crane crossed with a bridge, so it has many complex interior and exterior surfaces.
is there a lisp program or otherwise someone could please suggest to make my like easier trying to estimate the surface area?
I was thinking of something like the shrink wrap program for 2d, however for 3d solids.
I don't mind even if we need to use other software, but would prefer to stay with AutoCAD if we can
Replies (15)
Message 2 of 16
Washingtonn
You might try using the BLENDER software. Could you post a partial of the solids file?
Message 3 of 16
mvr_asp
hi thanks for your suggestion, i will put it to the team.
i cant supply a sample of the model unfortunately, besides being quite large,  i don't have permission to share it.
Message 4 of 16
leeminardi
How about the AREA command! Just give the command followed by an O (object) and select the solid.  Fast, easy and accurate.
lee.minardi
Message 5 of 16
mvr_asp
Thanks for your suggestion, yes something like that would be very accurate and easy, however I only need the outside surface area of a very large machine, for painting.
so inside walls do not need painting, or calculating.
however i will give your suggestion some thought
Message 6 of 16
leeminardi
It would be helpful to have more information about the "complex 3d solid".  I don't know if it would be feasible to use surfsculpt to fill the voids in the solid so that you have a solid that only has the external surfaces.  When using surfsculpt it may be necessary to "plug" holes in the solid to yield a watertight shape. Keep in mind that the plugs do not need to exactly fit the holes and may extend beyond the hole openings.
lee.minardi
Message 7 of 16
autoid374ceb4990
How about posting some screen shots of this complex machine? Could you post a front, right side, left side, and rear view?
Message 8 of 16
mvr_asp
hi there, I am not sure I can share a screen shot, however this is a google image from street view.
basically we have this in 3d, we need to work out how much paint to use to paint it.
Message 9 of 16
Washingtonn
It looks like it has been painted before....simply find out who did the first paint job and ask them how much paint they used. I would imagine that with cleanup, over spray, touch-ups and spills, the calculation for surface area per Lee's suggestion would end up being fairly close to what will be needed. Paint costs will be much less of a concern than the labor needed - scaffolding to access the surfaces and the actual painting.
Extra paint is not a bad thing when you need to handle areas prone to rusting and wear.
Message 10 of 16
mvr_asp
yes it has been painted before, in 1980.
Message 11 of 16
Tomislav.Golubovic
Fusion should be able to do it. You'll need to import a 3D solid and get Properties of it.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-calculate-e...
Message 12 of 16
SEANT61
Yes, that’s a complex 3dSolid alright.
The screencast attached demonstrates AutoCAD’s AREA command, as suggested by @leeminardi, with some additional steps to accommodate more complex solids.  This post/attachment is for general reference – which is to say that I would not necessarily recommend it for the project referenced by the OP.  It may be possible, but I wouldn't want to do it.
NOTE:  The XBOX Gaming screen capture feature does not pick up AutoCAD drop down menus, apparently.  At that midpoint, I used the SOLIDEDIT-COPYFACES command.
May your cursor always snap to the location intended.
Message 13 of 16
autoid374ceb4990
You cannot share the drawing and you cannot furnish screen shots of a front view.  Can you furnish a DWG of one or two of the more complex 3D SOLIDS?  Are there any other entity types that make up the area you are interested in?
Message 14 of 16
TheCADnoob
Have you tried providing drawings to a coating contractor? They may have methods for determining things like this.
CADnoob
Message 15 of 16
mvr_asp
I will see what i can do
Message 16 of 16
mvr_asp
yes that is the path we are looking at
