Change Comma to a Period - Acad 2025
[Post moved from Inventor Forum and title modified by CGBenner 9/13/24]
Hello, I'm using auto cad 2025 and had the issue of my dimension reading as a comma instead of a dot. if ur using an acadiso drawing it defaults to dimension reading with a comma. u can change to decimal by:
write "dim" into the command box, select "dimstyle," select modify, under the primary units tab find "decimal seperator" drop down box and change from comma to dot.
