Long drawing load times
02:13 PM
- Mute
- Permalink
- Report
CPU: Intel(R) Xeon(R) CPU E5-2603 v3 @ 1.60GHz (12CPUs), ~1.6GHz
Memory: 32GB RAM
Video: Quadro K2200, 4GB dedicated RAM
Model: PrecisionT7910
OS: Windows 7 Professional
AutoCAD Version: 2017
I have a 3.85MB .dwg that feels like it should be opening a lot faster than it is. I don't believe it is a network issue because it actually opens faster when it is on the network.
Here is everything that was done so far.
Spoiler
10/28/16 - https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Optimi...
4:05PM - Installed AutoDesk Service Pack 1
- Opened Autodesk and opened local file (desktop) - 23sec
- Closed file and reopened - 14.91sec
- Closed file and reopened - 14.13sec
- Closed and reopened AutoDesk - 23.22sec
- Closed file and reopened - 14.21sec
- Closed file and reopened - 14.5sec
4:14PM - Installed Accumulated hotfix 4
- Opened Autodesk Open Local File (desktop) - 23.88sec
- Closed file and reopened - 14.11sec
- Closed file and reopened - 14.34sec
- Closed and reopened AutoDesk - 24.42sec
- Closed file and reopened - 13.88sec
4:31PM - Set AutoDesk to run as Admin
- Opened Autodesk Open Local File (desktop) - 23.55sec
- Closed file and reopened - 14.69sec
- Closed file and reopened - 14.24sec
4:37PM - Disabled Run as Admin
4:38PM - Change the desktop theme in Windows to Windows Basic
- Opened Autodesk Open Local File (desktop) - 23.91sec
- Closed file and reopened - 14.14sec
4:42PM - Toggle hardware acceleration on and off in AutoDesk
- Opened Autodesk Open Local File (desktop) - 22.51sec
- Closed file and reopened - 13.60sec
4:55PM - Go to Options to the Display tab and turn off the "Show Tool Tips" and "Show rollover Tool tips"
- Opened Autodesk Open Local File (desktop) - 23.07sec
- Closed file and reopened - 13.57sec
- Closed file and reopened - 13.35sec
5:07PM - Created New Test File
- Opened Autodesk Open Local File (desktop) - 3.74sec
5:10PM - Copied data from test file to new test
- Closed and Opened Autodesk Open Local File (desktop) - 22sec
10/31/16
2:20PM - Webroot uninstalled
- Closed file and reopened - 13sec
- Closed file and reopened - 13.5sec
- Rebooted Computer
- Closed file and reopened - 22.88sec
- Closed file and reopened - 12sec
- Closed file and reopened - 12.97sec
- Re-installed Webroot
10/31/16 - http://forums.autodesk.com/autodesk/attachments/autodesk/248/39101/1/SPEED.UP.AUTOCAD.5-18-10.pdf
3:06PM - Performed -PURGE and purged "All" unused objects and references
- Opened Autodesk and opened local file (desktop) - 20.32sec (1.5-2.5 second speedup)
- Closed file and reopened - 12.50sec
- Closed file and reopened - 12.58sec
3:32PM - Changed SORTENT value to <0>
- Opened Autodesk and opened local file (desktop) - 20.67sec
- Closed file and reopened - 12.66sec
- Closed file and reopened - 12.52sec
- http://www.cad-notes.com/speed-up-autocad-optimize-computer/ & http://www.cad-notes.com/speed-up-autocad-configuration/
3:37PM - Adjusted computer Performance Options for "Adjust for best performance"
- Opened Autodesk and opened local file (desktop) - 20.39sec
- Closed file and reopened - 12.24sec
- Closed file and reopened - 12.39sec
- Adjusted computer Performance Options back to "Let Windows choose what's best for my computer"
- http://pinoycadcoin.blogspot.com/2013/04/20-ideas-for-speeding-up-autocad.html
4:06PM - Performed "Recover" on the local file
- Opened Autodesk and opened local file (desktop) - 20.93sec
- Closed file and reopened - 12.67sec
- Closed file and reopened - 12.40sec
4:31PM - Changed display settings in Nvidia Control Panel to "Performance"
- Opened Autodesk and opened local file (desktop) - 20.51sec
- Closed file and reopened - 12.34sec
- Closed file and reopened - 12.53sec
11/1/16 - http://blog.jtbworld.com/2008/09/autocad-2009-slow-performance-tips.html
9:45AM - Enabled Hardware Acceleration
- Opened AutoDesk and opened local file (desktop) - 23.40sec
- Closed file and reopened - 12.91sec
- Closed file and reopened - 12.79sec
9:51AM - Disabled Smooth Line Display
- Opened Autodesk and opened local file (desktop) - 12.00sec
- Closed file and reopened - 12.46sec
- Closed file and reopened - 12.18sec
- Re-enabled smooth Line Display
10:10AM - Disabled second monitor
- Opened Autodesk and opened local file (desktop) - 20.95sec
- Closed file and reopened - 12.33sec
- Closed file and reopened - 12.55sec
- http://blogs.rand.com/support/2011/05/tweak-your-systemautocad-for-better-performance.html
10:29AM - Installed latest graphics card drivers (9/15 to 10/16)
- Opened Autodesk and opened local file (desktop) - 21.80sec
- Closed file and reopened - 12.85sec
11/2/16 - http://forums.autodesk.com/t5/autocad-2007-2008-2009/xref-loading-speed/m-p/2338914
4:05PM - Reset -SCALELISTEDIT
- Opened Autodesk and opened local file (desktop) - 21.26sec
- Closed file and reopened - 12.78sec
4:44PM - Disabled "Apply solid fill" and "Highlight raster image frame only" in the Display Performance settings
- Opened Autodesk and opened local file (desktop) - 21.25sec
- Closed file and reopened - 12.25sec
- Closed file and reopened - 12.35sec
11/4/16 - Testing on large AutoDesk file
2:30PM - Opened Autodesk and opened local file (desktop) - 2min 18sec
- Closed file and reopened - 2min 3sec
- Closed file and reopened - 2min 2sec
- Performed -AUDIT and found 91 errors. 89 objects were erased
- Opened Autodesk and opened local file (desktop) - 2min 16sec
3:00PM - Performed -PURGE and purged "All" unused objects and references,
- Opened Autodesk and opened local file (desktop) - 2min 15sec
11/10/16 -https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Drawin...
9:08AM - Used commands : DELCONSTRAINT, PARAMETERCOPYMODE set to 0, WBLOCK
- Opened Autodesk and opened local file (desktop) - 20.31sec
- Closed file and reopened - 12.04sec
- Closed file and reopened - 12.22sec
10/31/16
- Rebooted Computer
Unfortunately I am unable to publicly post the .dwg, but I would appreciate any possible insight to this subject.
