AutoCAD Forum
Log is generated every time I start autocad now??
4 REPLIES 4
johnw
2269 Views, 4 Replies
For some reason when I open a drawing, a log is created in the folder where my drawing is kept. The log just basically shows what you would see when you hit F2 after startup. This has never happened before and I don't know why it started.
Any ideas how to stop this? (this is not the plot log).
John
4 REPLIES 4
jwhite
in reply to: johnw
There's a setting in Options to turn on log files. Did your get turned on by accident?
Tags (1)
johnw
in reply to: jwhite
I checked and saw no settings for generating a log. The only log option is for plotting and publishing and that is unchecked in both locations. Do you know where the setting your thinking of is located?
cadffm
in reply to: johnw
jwhite post a image, there you can see it !?
the normal *.log
Options/open&save/maintain a log file
Sysvars - use F1
logfileon
logfileoff
logfilepath
logfilemode
logfilename
other things (off topic):
options/plot&publish
plotlog *.log (and in plotstamp options/protocolle)
DWGLOG *.DWH (from Expresstool)
AUDIT *.ADT
XREF *.XLG
Sebastian
johnw
in reply to: cadffm
The maintain log was indeed checked. I must have overlooked that. Thanks.
AutoCAD Inside the Factory
