Lofting cross sections to a point. Centerline is not G1.
I'm not able to select the profiles without getting a "centerline is not G1". Is there some solution? It's the nose of a horse head.
Thank You!
parkr4st
septo
attached is what I did without your error message.
I moved some objects to Layer1 to get hide them.  They are still there for you to see if you turn Layer1 on.
I redrew the line work at the corner of the nose as your lines didn't meet quite right to get the loft to work.  Look for a small triangle to see what I did.
You need to rework that to get a real smooth surface intersection there.  Layer 2 has the surfaces I drew. ''Hope that helps
dave
parkr4st
Thanks for the kudos, but  feel all I did was get the nose so you could draw it without the message.
Is the real question "how to draw a 3d horse head?" for a rocking horse maybe?
I really appreciate the help out. It's actually a decorative ax handle I am making for my friend that is into Vikings. I used to work in Civil as a tech that's how I know about CAD.
