Loft Path not woking
dora0206
dora0206
After I make the loft, I hit Enter, type Path, select the path, then the loft disappears and nothing happens.
I believe the both ends of the path are connected to the cross section, so I hope to get some advices here.
Accepted solutions (3)
imadHabash
It's normal to get such a result because of unproper conditions for LOFT command. The rectangle is too big for the path and the circle. It will be fine if you reduce the rectangle for a proper size.
Imad Habash
j.palmeL29YX
The rectangle is too large for lofting along the small radii of the spline. Either decrease the size of the rectangle (as shown in the video)  or use a less bended spline.
Jürgen Palme
parkr4st
Almost
The short dimension of the rectangle is good and can be narrower or wider as it is parallel to the path
in the attached, I offset from the narrow rectangle until if failed to loft.  the red lines are almost at the limit. the limiter is seen from front view.
The soild will self intersect  causing the failure if the rectangle is 4056.52 + some amount which I didn't try.  at 4156.52 the loft fails.
j.palmeL29YX
When I wrote that the rectangle is too large in relation to the radius of curvature of the spline, that indirectly means (in this current example) that it is the rectangle's extension in X direction. In Y direction of course the rectangle can be as large as you want.
Jürgen Palme
parkr4st
so now my question is how to place maybe another spline or two to loft the rest of the solid in parts for a UNION?
j.palmeL29YX
@j.palmeL29YX wrote:
... means (in this current example) that ...
Jürgen Palme
