AutoCAD Forum
Loft command error
3 REPLIES 3
4025 Views, 3 Replies
Loft command error
I can't use Loft command in AutoCAD 2018. As You can see in the screen below, I want to build a 3D arch-bridge span so I have to connect all 2D blue (closed) polylines of each cross section. Each polyline presents a cross section of one steel plate of bridge span. I have 3 span cross sections and a path which is a 3D polyline but when I use a Loft command with path, AutoCAD gives me message: "Modelling operation error, Error Code Number is 98023"Loft.jpg
What I do wrong? Can anyone try this with my file below?
Loft command error
3 REPLIES 3
john.vellek
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I have been playing with this for a while and I think that the path is problematic. I tried to loft a simple circle from end to end along the path and it returned the same error message.
I was able to loft two of the cross sections along a simple arc and that worked fine. I was even able to SWEEP you end profile along the path.
The only way I got it to work with a loft was to rt-click on the 3dPoly and use a SPLINE Fit.
Can you try this and let me know your results?
John Vellek
Hi @Anonymous,
John Vellek
john.vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Hi @Anonymous,
John Vellek
in reply to: john.vellek
Yes! It works with 3d spline as a path. Thank You very much!
AutoCAD Inside the Factory
