load application error
Hello!
I'm having a problem when I'm trying to load an application to AutoCAD 2020. The app worked fine until yesterday, when I tried to acces any menu in the app, I got this error message: "error: no function definition: vlax-get-or-create-object". I tried unloading the app, and then load it again using Tools - Load Application. When accessing "app.lsp", ACAD said: app succesfully loaded, but when I closed the load app window it gives me this error message: "error: no function definition: vlax-get-acad-object"
Many thanks in advance!
Moshe-A
@Anonymous  hi,
key this in command line:
(vl-load-com)
now run the application
does this make the issue go?
moshe
Thanks for the quick answer, I managed to load the app without the (vl-load-com) command. but now I'm facing another issue. It's getting pretty frustrating, ; error: no function definition: dos_guidgen
P.S. Just now I realised that I get these errors only in some drawings. I don't get it, it's weird
Help, please!
Mark.Lancaster
@Anonymous
Not sure why this posting is in the installation and licensing forum..  It should be in AutoCAD and I have requested the moderator to relocate it there.
Anyhow do you have LISP programs running that reference the DOSLIB add-on for AutoCAD?   This missing function sounds like a DOSLIB function
https://wiki.mcneel.com/doslib/home
Mark Lancaster
