literal dim lines in xref drawings
Hey everyone! First time post.
I don't want to be the guy that doesn't check the past discussions for answers before posting a question, but I couldn't get the search engine to search what I am really asking.
So, I am working off a site drawing of an 80,000 sq ft production plant that was drawn by some old school drafters using probably AC 14.  Most of the departments are drawn in xrefs.  However, probably 10+ people worked on this project of mapping the plant so nothing is the same.  I cannot describe the frustration of inconsistencies of this drawing.  Alas, my question: some of my xrefs are shown in literal dim lines, what is going on?  When you go to the original xref, the lines are as bright as they always are.  When the xref is in the main drawing, the lines are dimmer than everything else.  Can anyone help?
Thanks in advance.
Blake
steve216586
Check the variable XDWGFADECTL:
Controls the dimming for all DWG xref objects. The valid XDWGFADECTL system variable value is between -90 and 90.
0 DWG xref objects are not faded. >0 When the value is positive, controls the percent of fading up to 90 percent. <0 When the value is negative, xref objects are not faded, but the value is saved for switching to that value by changing the sign.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
borges33
Here's a alternate solution to XREF dim.:
      Tools >Options > Display...On the bottom right side there is Fade Control Xref Display Adjuster,
     play with this and you will find your desired effect
