AutoCAD Forum
list command
15 REPLIES 15
Message 1 of 16
SANMIVR
880 Views, 15 Replies
list command
ths list command do not work on my 2016 version of autoCad, it opens a window with nothing in it.
15 REPLIES 15
Message 2 of 16
Alfred.NESWADBA
in reply to: SANMIVR
Welcome @Anonymous.autodesk.com!
Can you show a screenshot so we can see how the window (which pops up) looks like and we can also see what you have in your command line.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 16
SANMIVR
in reply to: Alfred.NESWADBA
Sure how do u do a screen shot?
Message 4 of 16
Alfred.NESWADBA
SCNR: >>>click<<<
- alfred -
Alfred NESWADBA
Message 5 of 16
SANMIVR
Thanks , there you go, don't know if it there, I could not open it.
Message 6 of 16
SANMIVR
Message 7 of 16
Alfred.NESWADBA
If you look to the forums page (instead of your mail system) then you should see the links here and also that there are no images attached here.
Sorry that I don't know what you meant by "could  not open it".
- alfred -
Alfred NESWADBA
Message 8 of 16
SANMIVR
Yes, before I sent to you, I tried to open the attachment but it did not
open for me to see it, were you able to see the screen shot?
Message 9 of 16
Alfred.NESWADBA
No, here (in the forum site >>>click<<<) there is no attachment in any of your messages.
- alfred -
Alfred NESWADBA
Message 10 of 16
SANMIVR
ok, how do I attach the screen shot here message?
Message 11 of 16
SANMIVR
Message 12 of 16
Alfred.NESWADBA
look to >>>that video<<<, at 1:40 you get the info about attachments.
- alfred -
Alfred NESWADBA
Message 13 of 16
SANMIVR
did u get it?
Message 14 of 16
Alfred.NESWADBA
>> did u get it?
Well, got it now, 😉
And now it's more clear what happend, you get the text-window of AutoCAD opened, which is normal with the LIST command, so that is ok
Now let's take a more detailed look to your screenshot, you do not only have issues with the background color of the AutoCAD textwindow, you also have issues with your status bar background (there you see different dark colors and you can't see all) ... so my guess is someone has played around with the Windows window colors and so the text window is present, but with black text on black background.
To proof my guess: try to mark text with your mouse in that textwindow as you would do it in any text editor, then right-click ==> copy, start editor or MS-Word ==> in the text-frame right-click ==> paste ... the content from the AutoCAD textwindow will now be readable.
Let me know if I'm right.
At least reset your windows display settings to default, there was something not ok.
HTH, - alfred -
Alfred NESWADBA
Message 15 of 16
SANMIVR
it is my fault, in the options, display, colors, section of autocad i made everything black, so i went back and changed back to white nad now i can see the text.
Thanks.
Message 16 of 16
"And now it's more clear what happened, you get the text-window of AutoCAD opened, which is normal with the LIST command, so that is ok"
My text window is opening when I use the LIST command but it is stuck behind my drawing window. It has worked fine up to today so I'm sure there is a simple fix. Can you help me?
AutoCAD Inside the Factory
