Lisp to create polyline with arrow in the ends, but not everytime!
Dear all,
Can someone help me?
I need to create A LOT of polylines in my projects and sometimes they need to have an arrow at the beginning, end, or both, and I think a lisp like this could be helpful, instead of create a polyline then copy an arrow to the end.
I'm new with lisp and don't know hot to do it but I imagine something that, after the command, when I click on the screen pops up a window with options "yes" and "no" so I can choose to put an arrow on the beginning, then I would click on everywhere I need to extend my polyline, and in the end, with ESC, it opens another window asking me again if I want to leave an arrow in the end or not. All this made with the current layer. I've tried to use "leader" but it's not what I need, although the style of the arrow was fine! With leader the arrow should be "Closed Filled" with size 2.5, if that can help with the style.
This is what I need:
I'm sorry if my english is not right, it's not used at all in my country
Since now, thank you for your attention!
RobDraw
Leaders should work fine. You can change the size in the style definition.
For LISP, I would suggest using the Customization and LISP forum.
Rob
Kent1Cooper
@RobDraw wrote:
Leaders should work fine. ....
Leaders won't give you the both-ends option.  But I agree, the >Customization Forum< is the place to go.
Kent Cooper, AIA
RobDraw
Personally, I don't use polylines for this. I use a block for the arrowheads and draw lines.
Rob
ВeekeeCZ
This should do the work. You can pre-select the existing pline to add arrows to it.
(vl-load-com)
;; beekeecz 21-08-01
(defun c:PArrow ( / :PLAddVertex e len)
  ;; From Lee Mac's code
(defun :PLAddVertex (e p / tan LM:LWVertices a b e h l n r w x z)
  (defun tan ( x ) (if (not (equal 0.0 (cos x) 1e-10)) (/ (sin x) (cos x))))
  (defun LM:LWVertices ( e )
    (if (setq e (member (assoc 10 e) e))
      (cons (list (assoc 10 e) (assoc 40 e) (assoc 41 e) (assoc 42 e))
	    (LM:LWVertices (cdr e)))))
  (if (and p
	   e
	   (setq p (vlax-curve-getclosestpointto e (trans p 1 0))
		 n (vlax-curve-getparamatpoint e p)))
    (if (not (equal n (fix n) 1e-8))
      (progn
	(setq e (entget e)
	      h (reverse (member (assoc 39 e) (reverse e)))
	      l (LM:LWVertices e)
	      z (assoc 210 e))
	(repeat (fix n)
	  (setq a (cons (car l) a)
		l (cdr l)))
	(setq x (car l)
	      r (- n (fix n))
	      w (cdr (assoc 40 x))
	      w (+ w (* r (- (cdr (assoc 41 x)) w)))
	      b (atan (cdr (assoc 42 x))))
	(entmod (append h
			(apply 'append (reverse a))
			(list (assoc 10 x)
			      (assoc 40 x)
			      (cons  41 w)
			      (cons  42 (tan (* r b))))
			(list
			  (cons  10 (trans p 0 (cdr z)))
			  (cons  40 w)
			  (assoc 41 x)
			  (cons  42 (tan (* (- 1.0 r) b))))
			(apply 'append (cdr l))
			(list z)))))))
  (if (ssget "_I" '((0 . "LWPOLYLINE")))
    (setq e (ssname (ssget "_I") 0))
    (progn
      (command "_.pline") (while (> (getvar 'cmdactive) 0) (command pause))
      (setq e (entlast))))
  (setq o (vlax-ename->vla-object e))
  (or *pa-t*
      (setq *pa-t* "End"))
  (initget "Start Both End")
  (setq *pa-t* (cond ((getkword (strcat "\nAdd arrows to [Start/Both/End] <" *pa-t* ">: "))) (*pa-t*)))
  (and (vl-position *pa-t* '("Start" "Both"))
       (< (vlax-curve-getparamatdist e 2.5) 1.)
       (:PlAddVertex e (vlax-curve-getpointatdist e 2.5))
       ;(not (vla-SetBulge o 0 0))
       (vla-SetWidth o 0 0 0.833))
  (and (vl-position *pa-t* '("End" "Both"))
       (setq len (vlax-curve-getdistatparam e (vlax-curve-getendparam e)))
       (< (- (vlax-curve-getendparam e) (vlax-curve-getparamatdist e (- len 2.5))) 1)
       (:PlAddVertex e (vlax-curve-getpointatdist e (- len 2.5)))
       ;(not (vla-SetBulge o (1- (vlax-curve-getendparam o)) 0))
       (vla-SetWidth o (1- (vlax-curve-getendparam o)) 0.833 0))
  (princ)
Thank you very much for this LISP @ВeekeeCZ, it's just what I was in need! You're awesome!
When I use linetype "dashed" the arrow shows dashed too. Is it something that I need to correct on my AutoCAD?
If not, can you please fix this for me??
I'm sorry for using the wrong area, I'm new here. It won't happen again!
