LISP or Command?
LISP or Command?
anderson51
Message 1 of 8
LISP or Command?
anderson51
I am trying to figure out how to write a LISP routine or generate an equation within a command that will take MASSPROP and divide that number by 17.28, then times it by 4.9.......when I click on a solid?
I apprecite the help.
Anderson
Replies (7)
Message 2 of 8
hmsilva
Anderson
Hi Anderson,
@ the Visual LISP, AutoLISP and General Customization forum should be easier to help with Auto/Visual LISP
Perhaps something like this to do the trick
(vl-load-com)
(defun c:demo (/ obj ss val vol)
    (if (and (princ "\n Select a 3D Solid: ")
             (setq ss (ssget "_+.:E:S" '((0 . "3DSOLID"))))
        (progn
            (setq obj (vlax-ename->vla-object (ssname ss 0))
                  vol (vla-get-volume obj)
                  val (* (/ vol 17.28) 4.9)
            (princ (strcat "\n The value is: " (rtos val 2 2)))
        (princ "\n You didn't select a 3D Solid... ")
    (princ)
Hope this helps,
Henrique
Message 3 of 8
anderson51
Thank you for the help, that works for selecting 1 solid.
Is there a way to set it up where you can window a group of solids?
Thanks again.
Anderson
Message 4 of 8
hmsilva
Thanks again.
Anderson
You're welcome, Anderson
The final result would be only the total?
Henrique
Message 5 of 8
anderson51
Yes.
Message 6 of 8
hmsilva
(vl-load-com)
(defun c:demo (/ obj ss tot val vol)
             (setq ss (ssget '((0 . "3DSOLID"))))
        (progn
            (setq tot 0.0)
            (repeat (setq i (sslength ss))
                (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i))))
                      tot (+ tot val)
            (princ (strcat "\n The value is: " (rtos tot 2 2)))
    (princ)
Hope this helps,
Henrique
Message 7 of 8
anderson51
Fantastic, thank you for the help sir.
Anderson
Message 8 of 8
hmsilva
Anderson
You're welcome, Anderson!
Glad I could help
Henrique
