LISP FOR DISTANCE BETWEEN 2 CIRCLE SELECTION
Jgmargarito26
Message 2 of 12
Jgmargarito26
COULD I GET SOME HELP, ON CREATING A LISP WERE INSTEAD OF PICKING CENTER POINT TO CENTERPOINT, YOU COULD BE ABLE TO SELECT A CIRCLE TO CIRCLE AND IT GIVES YOU A DISTANCE ON YOUR COMMAND BAR OR IN A DIM STYLE.
Replies (11)
Message 1 of 12
Jgmargarito26
Message 3 of 12
imadHabash
Try QDIM command .
Imad Habash
Message 4 of 12
Jgmargarito26
THAT ITS GOOD, BUT IT CREATES A DIMENSION I WAS HOPING FOR SOMETHING WERE IT TELLS YOU IN THE COMMAND BAR, WE DEAL WITH A HIGH VOLUME OF WORK SO SOMETHING FAST WITH OUT ME GOING BACK AND DELETING.
Message 5 of 12
Moshe-A
@Jgmargarito26  hi,
here you are but untested Smiley LOL
enjoy
moshe
(defun c:cdist ( / ss elist0 elist1 c0 c1)
 (if (setq ss (ssget '((0 . "circle"))))
  (cond
   ((/= (sslength ss) 2)
    (prompt "\nerror: select only two circles.")
   ); case
   ( t
    (setq elist0 (entget (ssname ss 0)) elist1 (entget (ssname ss 1)))
    (setq c0 (cdr (assoc '10 elist0)) c1 (cdr (assoc '10 elist1)))
    (princ (strcat "\nDistance= " (rtos (distance c0 c1))))
   ); case
  ); cond
 (princ)
Message 6 of 12
Kent1Cooper
The Customization Forum is the better place to request something like this, but quickly and in simplest terms [and untested]:
(defun C:C2CD (/ c1 c2); = Circle-{to}-Circle Distance
  (setq
    c1 (car (entsel "\nSelect a Circle: "))
    c2 (car (entsel "\nSelect another Circle: "))
  ); setq
  (prompt
    (strcat
      "\nDistance between Circle centers is "
      (rtos ; [in current Units mode/precision settings]
        (distance
          (cdr (assoc 10 (entget c1)))
          (cdr (assoc 10 (entget c2)))
        ); distance
      ); rtos
    ); strcat
  ); prompt
); defun
It could be made to verify that you actually picked two Circles, and not the same one twice, and could make different use of the information, etc., etc.
Kent Cooper, AIA
Message 7 of 12
Jgmargarito26
NO LUCKSmiley Sad
Message 8 of 12
Jgmargarito26
HEY THIS IS EXACTLY WHAT I WAS LOOKING FOR, IS THERE A WAY FOR IT SELECT MULTIPLE INSTEAD OF CHOSSING ONE CIRCLE AT A TIME? I KNOW IAM ASKING FOR TO MUCH
Message 9 of 12
Kent1Cooper
@Jgmargarito26 wrote:
.... IS THERE A WAY FOR IT SELECT MULTIPLE INSTEAD OF CHOSSING ONE CIRCLE AT A TIME? ....
I'm not sure I see the advantage in that.  You'd still need to make at least two picks, to define a window, or at best a pick-and-hold and a release using Lasso selection.  What if the selection contains more than two  Circles?  What should it do then?
Kent Cooper, AIA
Message 10 of 12
Jgmargarito26
WHEN I MEANT MULTIPLE I MEAN JUST 2 CIRCLES.
Message 11 of 12
Moshe-A
you are right, here's a fix
  (cond
   ); case
   ( t
   ); case
  ); cond
 ); if
 (princ)
Message 12 of 12
Kent1Cooper
Well, you can do this, to have it keep asking until you pick two and only two Circles:
(defun C:C2CD (/ ss); = Circle-{to}-Circle Distance
  (prompt "\nFor the distance betwen two Circle centers,")
  (while
    (not
      (and
        (setq ss (ssget '((0 . "CIRCLE"))))
        (= (sslength ss) 2)
      ); and
    ); not
    (prompt "\nMust select 2 and only 2 Circles.")
  ); while
  (prompt
    (strcat
        (distance
          (cdr (assoc 10 (entget (ssname ss 0))))
          (cdr (assoc 10 (entget (ssname ss 1))))
        ); distance
      ); rtos
    ); strcat
  ); prompt
  (princ)
); defun
But that seems a disadvantage to me, in terms of selection steps.  Not only do you still need at least two picks or a pick-and-hold-and-release to make the selection, but you also need to Enter to complete the selection.  For me, I'd rather use just two picks as in my first suggestion.
Kent Cooper, AIA
