Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
AutoCAD Forum
lisp file
5 REPLIES 5
664 Views, 5 Replies
lisp file
I couldn't find the lisp file for obtaining Bill of Quantities. So please send me the lisp file or the link to download it.
5 REPLIES 5
Alfred.NESWADBA
No need of a lisp file, just start command _DATAEXTRACTION and follow it's wizard (>>>details<<<).
If that does not work then please be more specific about which lisp-file you are referring to and why the above suggestion does not work for you.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Hello , In the following attached link,  we find a lisp file for obtaining the bill of quantities.
Is data extraction and bill of materials same?
https://www.youtube.com/watch?v=pHOHMZM_npI
https://www.youtube.com/watch?v=oTVcNb4h1Mk
Alfred.NESWADBA
"DATAEXTRACTION" is a command in AutoCAD
"Bill of Materials" is a technical term
So at least, no, that is not the same. But you can use AutoCAD command _DATAEXTRACTION to create a table like bill of materials. Have you tried it?
- alfred -
Alfred NESWADBA
ВeekeeCZ
Count is Lee's routine, available HERE
TLEN HERE
Next time I suggest you to use GOOGLE! It's easy find!
in reply to: ВeekeeCZ
Thank u so much. I got the required bill of quantity
AutoCAD Inside the Factory
