Linking Location Map (vic map, key map, etc) to Model Drawing Viewport
rrodriguez348
rrodriguez348
Community Visitor
Community Visitor
Hey everyone,
AutoCAD 2019 here and fairly new at CAD. When I design a construction plans,  I attach a location map in the top right corner (see screenshot) using GIS road lines and importing it as polylines. This could be ambitious but is there a way to link the location map and paperspace viewport so that whatever is visible in the viewport is highlighted or zoomed in on the location map? I attached two screenshots of what my ambition would be. Given the viewports in the paperspace, the location map highlights or possibly zooms in to give a better visual of where on the map the drawing is referring to
Tomislav.Golubovic
Not OOTB. The best way would be to make the viewports align with the grid of the site/project and then you could manually hatch the area it represents.
Having said that, there could be a LISP routine or code/app that does it for you. Did you look on the AutoCAD App Store?
