Linking a different tab name to text field.
J.S.H.
J.S.H.
I am new to AutoCad and was attempting to set up a cover sheet. On the cover sheet they like to have a list of all the pages such as:
DWG NO.                               TITLE
      C0-------------------------COVER SHEET
      C1-------------------------OVERVIEW
      C2-------------------------DETAIL
Is there a way of connecting the tab's tile to each text listed, so when I change the name page name from "DETAIL" to "CUT SHEET" it will change the text on the cover sheet respectively? Basically I can use the field ctab to make the cover sheet read "COVER SHEET" is there a way pull in the other tab names?
ChrisRS
Not the way you are hoping. It would be nice.
I suggest that you put your effort into learning Sheet Set Manager.  It has taken years but I am becoming convinced that SSM Makes sense, even if you are working with a small number of drawings or have all your layouts in the same drawing.
Sorry.
Christopher Stevens
Check out Mastering Sheet Sets at the below link. You can download a booklet taking you from the basics to customisation.
https://www.autodesk.com/cad-manager/manage-projects/mastering-autocad-sheet-sets
