lineweight doesn´t change
patriciotxk
patriciotxk
Hello to everyone,
I am writing because the line that I am selecting in the video doesn´t change its weight. Can someone telll me why?
Best regards,
Pedro Patrício.
imadHabash
i think that you have to check your dimension lines settings as i guide you in the previous post . check here for more information . >> Click <<
Imad Habash
vinodkl
The Lineweight is not changing because it's not a line, but its a Block reference. If you want to change the line weight of the particular line you need to go into block editor and then change the lineweight. To do that select the block right click and then select "block editor" now inside the block editor you can choose the line and then change it's line weight. If you are still not able to see the lineweight making any effect, type in the command "LWDISPLAY" and type in "ON".
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
