When plotting with plot styles the "use object linetype" setting in the plot style table is not working when i plot a pdf file. All the lines appear as continuous. I am unable to plot hidden, phantom, ect lines. Changing global scale has no effect.
Do the linetypes come out right if you print the PDF? What PDF plotter are you using?
The lines appear correct on screen. They preview and print as solid in both model and paper space regardless of LTS. This happens in all files for me in 2014.
I have discovered that it has something to do with hide command. The linetypes plot properly when plotted "as displayed". The lines become solid when using the hide command on screen or when being plotted with the Mview set to hide lines or in model space as hidden.
