linetypes should show as hidden but look continuous in DWG, perfect in PDF.
javier.zavala
javier.zavala
#1. Thes lines should show up hidden but look solid, as you can see other lines in show okay, but just visually not showing correctly or in plot preview as per below:
#3 but as you can see, once the plot is made and opened in bluebeam, the lines are now displayed correctly hidden
[ The subject line of this post has been edited for clarity by @pendean Original: lines should show up hidden but look solid]
Replies (13)
pendean
Community Legend
Community Legend
Your definition of "hidden" is referring to the close dashed linetypes, correct?
"solid" means CONTINUOUS, yes?
CANNOSCALE, CELTSCALE, LTSCALE, MSLTSCALE and PSLTSCALE variables in that file are set to...?
javier.zavala
yes sir continuous...sorry, the last three ive done also at times the lines will just disappear all together and not display visually or the "break pattern" will be just random, it will break into dots and continuous random sections.....again its more of a display issue in paper space and in plot preview, but once the plot is made it displays correctly in the pdf
javier.zavala
and what makes it even weirder is that if i close cad and reopen the drawing again, it displays just fine, but then once i close again and reopen the drawing once more, it has the issue again.....i am now noticing it is fixed and "un-fixed" if i open and close cad ...everytime
Kent1Cooper
Try the VIEWRES command.  Answer Yes to the question, and give it a high "circle zoom percent" number [despite the wording, it also affects noncontinuous linetype display] -- may as well go all the way to the maximum 20000.  It's a setting that affects only screen display, which would explain why things plot appropriately even though they don't look right on-screen.
Kent Cooper, AIA
pendean
Community Legend
Community Legend
Share a screenshot of your GRAPHICSCONFIG and ABOUT command pop-ups here too please.
javier.zavala
viewres...said yes and set to 20000 and did regen, nothing happened,...
Kent1Cooper
@javier.zavala wrote:
.... it is fixed and "un-fixed" if i open and close cad ...everytime
If VIEWRES fixes the display, that quote suggests to me that you have some customization that is messing with it.  Do you have an acaddoc.lsp file or APPLOAD Startup Suite entry that could be changing it?
Kent Cooper, AIA
javier.zavala
cannonscale set to 1:1
celtscale set to 2.5
ltscale to 24
msltscale to 1
psltscale to1
tried differnt numbers on all no "dice (luck)".....
javier.zavala
again its a visual issue not so much an issue with the actual linetypes per se i would think...notice agian ionly the lassoed lines are the once not "breaking" at all, when they should as per last image in pdf imagine 3
pendean
Community Legend
Community Legend
Turn off LINESMOOTHING and LINEFADING variables then REGENALL.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD.
javier.zavala
you know, one of those last ones (linesmooting, linefading) might have worked, i close and reopened cad and it displays correctly, but loike i said that if i reopen it again it usually goes back to "not displaying correctly" so i closed and opened thrice more and it is still displaying correctly as of now...please see below
dont know if it did it but i might have....
i guess ill keep checking and if it reverts back we will know....???
im inclined to say that it might have worked... i closed and r3e opened and again and opened other projects that with the same problem and theyre good now...hopefully it sticks..!
yeah man..! i think thats it yo! still looking good!
done opened and closed like ten times now and and all good...
cuz i did Turn off LINESMOOTHING and LINEFADING variables then REGENALL. and i remebr it didnt do nothing so i was sceptical about the gfxdx12....but once i closed and and kept reopening to test the theory....it now displays correctly everytime i do..
javier.zavala
GFXDX12 WORKED
javier.zavala
thank you
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
