Linetype scaling in a viewport
I have topography x-ref'd into a base drawing. The topo source .dwg and the base .dwg both have LTSCALE, PSLTSCALE, AND MSLTSCALE set to 1. I can tinker with the annotation scale in model space of my base... ...do a regen... ...and see it change.
But I want to go into a paper space viewport on a "topography" tab and keep the scale the same as other layout tab viewports... ...but change the "grain" of the contours so that they are "tighter" (with smaller and more frequent gaps).
I thought that I would be able to highlight the viewport... ...go to the "Properties" box... ...and change the "Annotation Scale" so that it's different from the "Standard Scale" setting... ...but I'm not getting the result I want. I can't seem to make the contour line segments/gaps shrink.
Why else would the "Annotation Scale" field and "Standard Scale" field be separate?
I appreciate any guidance.
