Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Linetype in drawing doesn't show up in .lin file
dslocum
Message 1 of 10
dslocum
I have linetypes in my template drawing that aren't listed in any of the .lin files that are saved in my default working folder file path. I want to edit the linetypes, but how can edit them if they don't show up in any of my .lin files? If I could delete them, I would just replace them with new ones, but I also can't delete them.
Replies (9)
Message 2 of 10
Alfred.NESWADBA
you need to export the linetype definition from the dwg into a lin file.
Therefor you'll need a tool like >>>this<<<
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 10
dslocum
Thank you Alfred. Do you know of a way to force a delete of a linetype definition? We have dozens in our template that never get used, undefined shapes, etc., but they won't delete.
Message 4 of 10
dslocum
Alfred, I loaded and executed the LINOUT command and returns the error "bad argument type: stringp nil". I assume it's not compatible with Civil3D2025. Is that the issue?
Message 5 of 10
pendean
Community Legend
Community Legend
@dslocum Let's ask that custom tool developer/coder @vladimir_michl about your issue with their LINOUT tool, can you provide a DWG with that one linetype in it?
Message 6 of 10
dslocum
Thank you. The dwg is attached.
Message 7 of 10
vladimir_michl
Hi, it should be compatible with all AutoCAD flavors 2016+. But maybe not with DGN-imported special linetypes. Can you please send me the DWG (at least a portion of it) showing this error? PM or e-mail - vladimir.michl @ arkance.world
Vladimir Michl, www.arkance.world  -  www.cadforum.cz
Message 8 of 10
vladimir_michl
The linetype "V-WETL" points to non-existing shape (SHX) definition. The app will be updated to handle such special case but in any case this linetype is corrupted.
Message 9 of 10
vladimir_michl
The app is updated now - V1.4
-vm
Message 10 of 10
dslocum
Thank you!
